Flasher 4 97 Eclipse gt location
Hello I hope I can get a little help .I cant seem to locate the turn signal flasher unit on this 97 eclipse gt.I was told to the right of the sterring wheel. But where I cant see it if anyone can please help me ,I thank you . The reason is the blinkers have just quit.The fuse seems to be fine and still no signals.The emergency flashers still work but I was told therey both have there own side of the flasher .Now any help would be fine .or a pic also Thanks again.
RE: Flasher 4 97 Eclipse gt location
First off, a 97 is either the GS or GST, which shouldnt really matter if its turboed or not.. Flashers are usually in the fusebox on older cars, but yours Ibelieveshould be mounted behind your vents in the middle.. If you pop those out you should see itmounted on theright side..
