-   Interior Wiring (https://mitsubishiforum.com/forum/interior-wiring-55/)
-   -   need help wiring colour code (https://mitsubishiforum.com/forum/interior-wiring-55/need-help-wiring-colour-code-17392/)
outlander 2003 Mar 18, 2007 08:12 AM
hello all,
i was just trying to install a new head unit in my 2003 outlander and i was wondering if anybody here knew the colour codes for the wiring
need help urgently
thanks
kevin
instaldave Mar 18, 2007 03:46 PM
RE: need help wiring colour code
Did you cut off the factory plug? If not you should be able to get a wiring harness to plug directly into the factory harness and the colours will match up to the aftermarket unit. If not you will have to rewire the amp that is located under the drivers seat.
Radio 12v
http://www.directechs.com/images/clear.gif
red/black
radio harness
Radio Ground
(chassis)
Radio Ignition
blue
radio harness
Radio Illumination
green/white
radio harness
Factory Amp Turn-on
N/A
Power Antenna
N/A
LF Speaker +/-
white/blue - black/blue
radio harness or amp under driv seat
RF Speaker +/-
white/red - black/red
LR Speaker +/-
yellow - gray
RR Speaker +/-
yellow/red - gray/red
