Internal Lounge Chat about beefing up your insides here.
Eclipse Problems
Old Oct 25, 2007 | 06:15 PM
Bgonz84's Avatar
Default Eclipse Problems
I have a 97 Eclipse 420a converted to a 2.4 i recently found out that the guy that installed the engine for me didnt time it right, turns out i had to flip the cams around to make them 2.4 instead of 2.0 not a big deal.
but my rear main seal keeps leaking. ive replaced it once already and the car has only been driven about 1 mile. im sure once i actually get around to flipping the cams everything should run better. but the damn rear main seal is pissing me off.
not to mention i have to get a new transmission mount. do you think that is what could be ruining the rear main seal ?
let me tell you what i have done to it and maybe there is something im missing.
Overbore .20, Obx Intake manifold, Obx headers, Performance Cam gears, Lightweight underdrive pully, Short ram intake, polished crank, new engine bearings,
whats the deal ?
Old Oct 25, 2007 | 09:44 PM
nick_200321's Avatar
Default RE: Eclipse Problems
what you replaced the rear main seal, did you replace the gasket that goes around it? that could be leaking
Old Oct 26, 2007 | 07:57 AM
You cant "flip" they only go on one way from what i remember. And doing that doesnt make a car go from 2.0 to 2.4. The pistons, and crank are what convert to a 2.4, it have nothing to do with the head. If its out of time then check the came gears and make sure the marks are all lined up correctly
Old Oct 26, 2007 | 11:21 AM
I dont think he was saying the cams make it a 2.4... but what i dont get is why you would think the cams one way work for the 2.0 and the other way work for the 2.4? Confusing
Old Oct 28, 2007 | 01:29 PM
Bgonz84's Avatar
well what i was saying is that the timing on the engine is different because of the bigger pistons, on the cam gears themselfs one side says 2.0 and on the other side it says 2.4. the guy said that the timing on the crank has changed and i wouldnt get full power until i atleast flipped the cams to the reverse side. but im still not sure. i just need to take it to this guy and see what he can do for me, i dont have the time to be doing this stuff myself. besides he said he was the only one in his county that did 2.0 to 2.4 conversions. i just want my damn car to work again.
Old Oct 29, 2007 | 08:42 AM
that makes no sense. Ive never heard of cams being able to be "reversed. They only go in one way
jp2000
Jan 1, 2012 05:21 PM
p4c0
Feb 22, 2007 06:36 PM
2GNTeclipse
Aug 29, 2004 09:40 PM
Ooopsy67
Jun 30, 2004 10:16 AM
kevlst
Jun 14, 2004 12:16 AM
