Transmission Pan
Well im having a problem with my transmission pan gasket. The gasket is leaking, BUT heres my problem.... One ofthe bolts that hold the pan on is stripped. It takes a 10mm but the socket just turns over it causing it to strip more. Would it hurt me any if i was just to take a chisel and cut that 1 bolt off? I have the new gasket and all other bolts come out fine. I dont know though, its already leaking (Very slowley) 1/4 quart every 100 miles. Should i just leave it alone? Or will it still leak with 1 bolt chisled off?
Thanks guys
Thanks guys
You want me to pull out my camera and take a picture of it for you?
Better yet, pull out your haynes manual and look up manual transaxle.
Car has oil pan and a transmission pan
http://www.autozone.com/R,APP1129470...ductDetail.htm
somepeople call it the transmission pan, others the manual transaxle pan, either way same part
ooooo. ok this is making alot more sense now. I kept thinking your talking about a manual since you said manual twice in your last post
Ok yea id try some channel locks. Those are probably the easiest way to get a good grip on a stripped bolt
