1991 3000gt -- 1993 stealth rt SWAP???
hi im new to these forum and I was wondering if anyone would help me with this problem that I have, I want to change my broken tranny manual from a stealth rt 93 to put it in my 91 3000gt sl but reading I realized that that a 2nd generation car according to what I read and will not fit on it, is there anyway possible that I can make it fit my car and if I can what can I do to put it in my car.
thanks
MAG
From what I have read, the Getrag Transmissions are the same with the exception to the 6th gear added to Generation #2. The gearing is all internal, so the casing on the outside should be the same. I may be wrong, but I think, based on this, that it should fit.
i was a little confused @ the original post, but are you saying that a 91 and a 93 are two different generations of cars? if you did say that, i think youve got it mixed up. cars years 91 through 93 are considered first gen.
and then i think 94 through 98 are second gen
then 99 is third gen.
if that helps you any through the process
and are you a part of www.3si.org ?
if not you should join there and i've noticd that more people respond to things over there. and for the most part everyone is either driving a 3000gt or a stealth over there, so it seems that theres a little more info over there. not to put down this site
_isiah
_isiah
ORIGINAL: 94 3kgt sl
mine is a second gen, and says its a 94 but the thing on the door jam says it was made in october of 93. maybe thats what he ment by it being a 93.
_isiah
Stealth ES Dragon
12-10-2005 10:33 AM
