3000GT wont start - Help plz !
Dear All,
I have a 1995 Mit. 3000GT and since sometime now, it wont start when I press the Ignition to it (by turning the keys). Then, I have to jump start it. I went to Autozone and had the battery replaced; yet it does the same. O'Reilly and Autozone told me that the Battery and the Alternator are good. And if there was a problem with the starter, it wont even start with a jump Start. Again, I checked all the connections to my battery to see if it was leaking some current out, but it wasnt. Can anyone please give me a clue about what to do ? Coz every single day, I have to jump start it and I dont know if there any problem with the Battery or the Alternator or the Starter ?? Your any help in this regard would be fairly appreciated. Thank you in Advance. Love & Regards, Jimmy. |
where are you located?
I am located in Rolla, MO.
And I was just searching for the issue on google .. it is referred to as "click, click, start" problem for 3000GTs which is fairly common. The link - http://supercar-engineering.com/rubb...Fix/index.html gives a way to fix it. has any1 tried it ? |
Replace the starter.
