3sx motor mounts vs stock motor mounts
my car needs a good pair of motor mounts .. i was orginally going to go with the 3sx ones because they look better and they are performance motor mounts but what worries me is in the description it says the car wit vibrate more at idle?? wha do u guys think and witch one should i buy??
[IMG]local://upfiles/16732/DDAB8520A917461F90184DB9A86A0B50.jpg[/IMG]
[IMG]local://upfiles/16732/A89EF1B074974A1BB7AF9D225AF60024.jpg[/IMG]
We had the solid motor mounts in a few cars here, and it's really not as much of a vibration as you'd think. It makes the car sound slightly different, but that's about it. The car will also feel faster.
BTW, 3sx just re-sell's Maximal Performance motor mounts. Buy directly from Maximal Performance. It'll be cheaper.
Your gonna notice a lot more rattles. Some people can't stand them but a majority of the people out there won't go back to stockers.
I've heard of people using two solids and (cant remember if we have 3 or 4 mounts) stock ones to try and damper the vibration.
ORIGINAL: EMC 3000GT
Some people do just buy 2, which is more than enough to keep the engine from rocking. But you may as well replace all 4 in you're in there. They're not entirely too expensive.
We had a modded 98 Vr-4 with solid motor mounts, it's really not that noticeable, and not bad at all. It makes you feel more... in tuned with the car... if that makes any sense. LOL They're great, I definitely recommend getting them. Or poly mounts. But I think the solid's are actually cheaper through Maximal Performance if I'm not mistaken.
i only changed two and the car vibrates like crazybut when idle'in u can barely tell its just on take off idk if i need to change the other two or keep it how it is ... and i didnt change the other two because they seemed to be in good shape .. if anyone here rebults them i will gladly give you my two ones that are bad
