Blow-off valve
Blow-off valve
After installing a blow-off valve I notice that my idle rocks up and down. All the vacuum hoses are connect and there are no leaks. Adjusted the cam angle sensor and check the mass flow sensor. What is goin on? It's driving me crazy!
RE: Blow-off valve
The blow-off valve that I have is a venting type. I will check the blow-off valve for leaks. When first installed it the car was running fine. About a week into it the idle problem happened..
95HGeclipse
05-29-2006 02:26 AM
