buying a 93 vr4?
I really have to dissagree... i have heard of a couple... but i have heard of say... 5 DSMs spinning bearings... and about 2 VR4s... and one was because the owner was a d-bag and never changed the oil once in the cars life.
ORIGINAL: isiah
as sebba said about the timing belt, also make sure that the complete 120000 service was done. i know the timing belt is a big part of it, but i'm pretty sure that theres much more. and good luck with the whole thing.
most 3kgt owners say change the belt every 60k miles........
ORIGINAL: Sebba
Emonz is right, but not without reason. Without doubt, the 4-bolt blocks are stronger than the the 2-bolt ones. What I think happens, is people by an older car that is broken in, tolerances are loose, oil passages aren't perfect and they start upgrading the power. The increase in power is just too much for the old engines to cope with. Also, when extensive upgrades are made, usually some kind of after market engine control unit is used. Poor tuning and logging will kill an engine as quick as anything. People have built reliable and powerful 2-bolts and have not had any issues.
Preventive maintenance is the key...but that is pretty much universal.
ORIGINAL: 99madewell
ORIGINAL: isiah
sorry if i was unclear before
ORIGINAL: Sebba
ORIGINAL: isiah
yes, true that... but, what did he say the car had on it? something like 140000 miles on it. which is 60000 times two plus arund 20000 miles. it's not to the point of 180000 mile tune up yet, so i just figured the last one that would have needed to be done would have been the 120000 tune up.
ORIGINAL: isiah
![Wink](https://mitsubishiforum.com/forum/images/smilies/wink.gif)
i baught a 93 vr4 after 250 miles it had a spunn bearing and then the oil pump went and then the engine seized : () so i didnt have the best of luck with mine but hey maybe u might have better luck just make sure everything is good with the engine
