cooling fans ??
having trouble with my cooling fans there on the hole time and wont turn off when the temperature is around the middle dash
temperature only rises when i turn on the A/C but i almost never turn it on so idk what to do any advice?? |
RE: cooling fans ??
Well you should switch the termastat. My 3000GT used to do that and the termastat wasnt relasing that much water when it will heat up in which it will cause the fans to turn on. So try that out.
RE: cooling fans ??
sounds about right.
