Headlight Replacement - '93 3000GT SL
Ok, I give up :) I know this has got to be simple, but have never changed headlights on a car with flip-up lights. Does anyone have step by step instructions for changing the headlights on a 1993 3000GT?
Thanks! JD |
RE: Headlight Replacement - '93 3000GT SL
Use the botton on the dash to raise the lamps with the light off, remove the covers on the side of the headlamp to expose the metal bracket that holds the lamp in place. When removing the bracket, be sure to only remove the screws that hold it in place- NOT the ones that adjust the aim. Good luck!
J |
