I need some advice
Old 07-29-2008, 03:24 PM
john1006's Avatar
Default I need some advice
Ok i have a 1992 VR4. I just replaced the clutch, spark plugs, wires, fuel filter and all the fluids. Now after i replaced everything when i go to accelerate it starts cutting out at about 2900 rpm. Then it cuts out for a second, but after about 3500 rpm it doesnt do it, until i shift and it gets back at 2900 rpm. Any suggestions as to what it could be?
Old 07-30-2008, 07:11 PM
reggieccrgto's Avatar
Default RE: I need some advice
I had the same problem with my VR4. You might want to check the BOV and any air intake, intercooler holes for leaks.
Old 07-30-2008, 08:16 PM
john1006's Avatar
how would i check for leaks??
Old 07-31-2008, 08:36 AM
easy way I checked was spray all the possible area's of leaks with choke cleaner. engine will change speeds when leak is detected
BE CAREFUL..it's flameable!
Old 07-31-2008, 10:15 AM
Thats a dumb ****ing idea.
Google 'boost leak tester' and that should tell you everything you need to know
Old 07-31-2008, 11:17 AM
john1006's Avatar
thanks guys, it was a vacuum hose like deep in the middle of the engine lol ok i have one more question. i filled my transmission with gear oil, is there also a place to fill the transfer case or does it get gear oil from the transmission?
Old 07-31-2008, 11:57 AM
I guess your talking to me? Nice guy! I used to work on imports for years, and I found many a leak this way. The guy asked for an idea.... didn't know I would get such a "nice" reply from someone whom didn't even ask the question.
I will be more careful in posting from now on... if ever. gezz.. some people just can't help being a rude when posting online.
If this is the kind of people that own 3000GT's... I think I will rethink "joining the club" by purchasing one.
Old 07-31-2008, 10:15 PM
I side with you BrianWSNC. You gotta have thicker skin with some of these older members. Just have to remember they are old.
John1006 Im glad the advise worked for you.
Old 08-01-2008, 09:38 AM
Thanks for siding with me Reggie. As for age, one would hope an older person would become wiser and more accepting of other people's oppinion, being they have seen more in their life.
By the way, I am 53. just three years past the half way mark!
Old 08-01-2008, 02:27 PM
john1006's Avatar
Quick Reply: I need some advice
