twin turbo swap on sl???
I was just wondering if anyone has done this... I found a vr4 at a junkyard near my house. I was just wondering if anyone knew whatI would need to get from it. Also does anyone know if the pistons and rods are the same? Any help would be greatly appreciated.
RE: twin turbo swap on sl???
The pistons are different for sure. Not 100% about the rods but i believe they are. You can do the swap fairly easily. You will need the motor, ECU, exhaust.... hmm... am i missing anything else?
Yes, there is a difference between the 2 bolt-4 bolt main oil pans. I think the only difference between the NA and TT oil pans (of the same generations) is no oil return bung on the pan. They may be other differences, but I'm not sure.
