TwinTurbo help
TwinTurbo help
what causes problems with tour/sport suspension mode on '91-'93 stealth/3000gt r/t twin turbos? mine was working fine, but now it conintuously blinks tour/sport, and hitting the ECS button doesnt help... thanx
RE: TwinTurbo help
In most cases, the wiring harness going into the front struts will break causing an open in the circuit. Remove the black cover of the front shock towers and inspect the wiring harness that plugs into the top of the strut- you may find an open wire there. It eventually breaks after having flexed back and forth due to several years worth of turning left and right. All you need to replace is just the black cap and harness. Good Luck!
Joel, CA
Joel, CA
