uninstall viper alarm????
hello i have a 95 3000gt sl and was wondering how i uninstall it because when i put the battery clamps on the alarm goes off so i unpluged the viper alarm and tryed to start it and it would not start. i know when i put the key in the door and turn it is supposed to shut the alarm off but it does not shut it off. so please tell me how to fix this or uninstall the alarm.
thank you |
RE: uninstall viper alarm????
You might have to go to a shop, each alarm is different. If you know which one you have then you can look up what all you have, there are various sensers and relays that will disable the vehicle if disturbed. So after you find out that you can disconnect every thing and re establish all stock connections. If you want to try and fix it find the brain probablly under the steering wheel and see what devices you are using (trunk pop, infared detector, vibration detector, ect...) then you can check each one of those things to see that they are working properly.
