Mitsubishi Diamante For the faithful Mitsubishi owner, this car offers high end luxury without high end luxury pricing.
battery/ brake light problem solved.
Old 03-08-2019, 12:36 AM
weevensteven's Avatar
Default battery/ brake light problem solved.
I recently purchased an 02 diamante and the battery light was coming on randomly. Each time I would shut off the engine and restart it and the alternator would begin charging again. I found that the battery cables would not tighten on the top posts so I bought some top post shims from AutoZone. When I went to install them, I found that someone had tin foil wrapped around the positive post thinking this would work. I removed the foil, installed the shims and haven't had any problems. I hope this information will help someone with the same issue.
mainelary
07-12-2021 10:32 AM
Brian Yazzie
01-23-2012 09:49 PM
jeedizzle
10-13-2009 10:08 AM
EclipseFLAGirl
11-09-2008 11:10 AM
serenabkhan
11-23-2007 05:44 PM
Quick Reply: battery/ brake light problem solved.
