clicking noise when adjusting cabin temp
I am convinced that it is a blend door motor but I cannot find a part # anywhere. Can someone please tell me what it is and if there is a website to order one other than going to the dealership......thank you!
I have an 03 Diamante |
Here is the part #'s to the motors if anyone needs them. These are good for diamantes years 97-04.
The "mode" motor located on drivers side behind center console mounted vertical is pn: AW339321 and the "temp" motor is located on passenger side behind center console mounted horizontal p/n: AW342508 |
Clicking noise
I had the same problem. Turned out it was a damper control motor. Small electronic device about the size of a pack of cigarettes. There are several of them in the system. I contacted SW Mitsubishi in Weatherford, TX and purchased the part. They sent me several of them....I figured out which one I needed and returned the others. They issued a credit promptly. Their prices are the best and their service is great.
Clicks @ startup
Mine clicks @ startup for abotu 30 second 1/2 second apart.
Then it is silent till the car is restarted. What could it be ? Cool. Srinath. |
Clicking noise
It is one of the damper control motors. It is broken and continues to attempt to move the vents to control the airflow. There are several different ones in the dashboard behind the climate control panel. See a diagram of the hearting and ac system. Dealer will charge about $400 each for them. I got them from SW Mitsubishi for about half that.
Why is it doing it @ startup
Its doing it @ start up, we're not adjusting anything then.
Thanks. Srinath. |
Why is it doing it at startup?
Because the control motor is broken. It keeps trying to go to the setting selected on the climate control. After 15 seconds it will stop but starts again when turn off and restart.
Originally Posted by Jason Duhaime
(Post 295438)
I have an 03 Diamante It does this to redirect the airflow away from your face and feet until the coolant temp reaches a level where it's comfortable for the passengers in the car. |
Just went through this. The horizontal mounted one was bad, very pricey part. Took it apart and one gear, the one that drives the pie shaped gear on the actuator, had a missing tooth. Was able to re-time/realign the gears so the missing tooth does not come into play, works fine. Easy part to remove, pain to reinstall. The cable for the motor has a retainer holding it in place in the steel framework, pop out that retainer and the remaining hole lines up perfectly with the one mounting screw, long magnetic phillips screwdriver.
