heated seats
heated seats
I don't know where to start to troubleshoot my heated seats. They don't seem to be powering on. They have no light other than the one that comes on with the headlights. Is there a fuse that I can check for them. I don't see anything indicated in the manual for a seat heater fuse. If anyone knows where it is I will check it.
If it helps with diagnosis I also have problems with the radio, it is on and it is locked on a station but sound only comes out of it when it feels like it. It will not work for weeks and then it will just come on for no reason. The passenger window doesn't go up or down but someone told me it isn't the motor because he put power to it and it went up and down fine. I also tried a new window switch in that door and it didn't work. I also have no power antennae anymore. It stopped working. I got a standard antennae. And it worked fine while the radio worked. Could these problems and the seat all be related? All the other windows, and door locks work fine so far.
Thanks for any help.
heater fuse
langk, thanks for the reply. It is a 2001. I may have a fuse there for it but my manual has no symbol for a seat fuse or a seat heater fuse either there or for the fuse block in the engine compartment.
