I did the Heater Core O ring fix - now WTH !
2002 Diamante
Heater core gaskets were leaking did the DIY fix .... THANKS by the way Am positive there is no coolant leaking past the new o rings. Totally dry. I THINK I was very careful to not let coolant leak all over the place when I loosened up the brackets to take the old o-rings out. Put it all back together and still get a blast of coolant smell when I turn the system on. This is what I've done to try and fix it: Took everything back apart to get to the heater core. It's still dry. I don't see any coolant on the core fins, which makes me think the core isn't leaking. I figured there was coolant residue on the "other" side of the core....inside the duct work. I covered the transmission computer module with plastic and towels. Using a garden sprayer I sprayed hot water thru the core, all over the foam that hold it in place, etc... My thought was there is coolant residue and maybe I can dilute and flush away. Well that has not worked. Still get coolant smell. Any ideas? If any of you guys did the fix and still had a residual coolant smell, did it eventually go away? PLEASE HELP....AAARRRRGGGGHHH!!!!!!! |
