Pulling a F4A51 transmission
Hello,
I am attempting the dreaded transmission swap - I am swapping a 2002 tranny for one out of an 03. How hard is it to do ? Do I need tranny shop to do it, or is it shadetree mechanic ablity. I mean I have a regular mechanis who does everything, including fix the timing belt water pump when it jumped ... should I try him Cool. Srinath. |
The mitsubishi strikes again.
Bad transmission relay, and swapping it from the parts car fixed it. Cool. Srinath. |
Broke again
OK the "fixed" car is now dead again.
Now the transmission is completely dead, no forward gears at all. A few mins before it died the car was going forward in Reverse. No noises, grinding or anything. I still think its electrical. Has anyone had this happen ? Thanks. Srinath. |
did it work in between swapping the box and being "completely dead"
if not, you done f*cked something up. go and buy a car 15 years older, they're so much easier to fix. |
It worked for 1000 miles
Yes after swapping the transmission solenoid relay it worked for over 1000 miles and 2 months.
I think its still electronic though ... solenoids or something. Cool. Srinath. |
And the "dead" transmission - which before going "dead" went forward in reverse - about 20 mins ago went into reverese when you put it in Reverse, and backed up a few feet ...
Cool. Srinath. |
What controls the shifts in the transmission ... 2002 diamante - I think its not got a TCU. The ECM ?
Thanks. Srinath. |
