Were to find rear upper knuckle bushings for 99 Diamante
I have searched far and wide for replacement 1999 Diamante rear upper knuckle bushings and have only found that there is a tool to do it and that they can be changed .But no part #s or any manufacture that make them. Seems that they can be found for other Mitsubishi models around the same year but no listing for the Diamante. I called Mitsubishi dealer and they were no help. I have searched for hrs but there is never a part # when I have found forums were it has been talked about. It could also be called a Rear axle carrier Bushing. Any help would be great
I have the same problem with mine except that its the lower bushing that it needs. I have removed the entire knuckle on mines and this is the number for the top and one of the lower bushings (mr223673). It might be different all depends when the car was made, just throwing it out there just in case. Mines was made in August of 98 and has disk brakes all around. Hope this can be of some help, try googling it or geting back to the dealer with that number.
ZPartsHouse
Feb 23, 2008 03:04 PM
