Wiring Issue
1 Attachment(s)
1992 Mitsubishi Diamante Wiring Problem
( 1992 Mitsubishi Diamante 6 cyl Front Wheel Drive Automatic with 6G72 Engine ) Hi , above the ignition coil is a piece with two capacitors, the 3 pin harness brokes and now i have 4 loose wires (white/black, white, black/white, brown/white+ground) from the engine side. Could anyone helpme with the correct pinout?. Thanks in advance.. |
