Mitsubishi Eclipse & Eclipse Spyder For years, the Eclipse line has stood for cutting edge styling and performance at an affordable price.
96 eclipse rs (what to do now)
Old May 26, 2010 | 07:20 AM
1996-gs-eclipse's Avatar
Question 96 eclipse rs (what to do now)
Ok I have a 96 rs eclipse that I am having problems with. About a wee ago it started, after it has been runny for about 10 mins it would die and won't start back up untill u waited like 15 mins. So I hooked it up to a scaner and it gave me 4 codes but there was no check engine light on. Well it all came down to change PCM. So I did and it fixed all my little problems but still dies. And sence I changed the PCM right before it dies the check engin light flashes the stays on. And if you push the gas right when it starts to mess up it will spit and back fire... I been told to change the fuel presure regulator and the camshaft sensor, but I want someone eslses advice...
Old May 29, 2010 | 08:37 AM
Default Help
Ok I hooked up a scaner to my car and it said camshaft posion sensor, so I put a new one in and the code still comes up, so I check all the ohm and voltage specs and they are all right were the should be, could it be my new PCM or what else could set a camshaft code othere then the sensor???
Soccrluv
Jan 31, 2009 12:27 PM
06_Eclipse
4th Generation
Nov 18, 2008 06:53 PM
isimon77
Mar 24, 2008 08:21 PM
joe2106
Feb 12, 2008 01:35 PM
EvoIIIswap
Nov 9, 2006 04:44 AM
