eclipse spyder 08 top problem-help needed
Hi everyone. I just got my Eclipse spyder 08 and after shipping for few weeks, i have some problems with the top. when i try to close it from half-open position, it closes perfectly, but if i try to close it from fully opened position in one continuous movement (holding the close button all the way till closer) the top closes and as the rear part closes it stops on touching the back surface ( looks like fully closed) and i get 3 beeps instead of one long. After that, the top won't close or open and if i drive it beeps like i am driving with a partly open top. After a few hours to couple of days it disappears and I can operate the top again but with the above restriction. Does anyone have any idea what might be the problem? Thanks boaz |
Had the same problem with mine.Warranty covered it and it was a wiring/ module issue under the back cover.
Had to wait for parts and then they replaced it and it has worked fine since. Gretzky |
