manual trans
Can a manual transmission from a 1990 Mitsubishi eclipse be put into an automatic 1994 mitsubishi eclipse?
_________________ Like a cop car. Got truck parts Mrs. Officer? |
Yes as long as it a non turbo engine. You also will need a pedal assembly, shifter assembly, clutch master, slave, shift cables, clutch kit, flywheel and I believe thats it. Your also gonna have to drill out holes for the clutch master cylinder to mount it and a hole for the shifter calbes.
