2004 Endeavor Camber Adjustment
I recently had to replace my rear tires because one side was worn down to the strips. After they were done I was told that my alignment was off due to my needing to adjust/replace my camber bolts. I have looked all over the web and there's not much in the way of explaining anything related to Mitsubishi. I haven't even found a service manual. My question is, how do you adjust these camber bolts...what is the proper adjustment...how do I tell how much to adjust these bolts? Pictures and/or diagrams would be most helpful.
Purchase 2004 service manual cd from Helminc.com
Section 2 (Rear suspension) has diagrams and all relevant info that you require. Hope this helps Kirstenbosch19 |
