SRS or airbag light on and won't turn off
Old 01-30-2019, 10:56 PM
bordermec's Avatar
Default SRS or airbag light on and won't turn off
I have a 06 Endeavor, owned since new. I never had many problems with it until now. These are the codes that I have B1481, B1487, B1489 and U1073. I have searched for Mitsubishi codes and Endeavor codes and I am lost as to what they mean. I can't clear the the codes with my Creader VII+. I can't find any reasonable direction. I am sure that this question has been asked many times, I am a retired mechanic and totally lost any help would be greatly appreciated THANKS IN ADVANCE.
Old 02-06-2019, 02:08 PM
dnwoll's Avatar
Default codes
Most SRS problems are a bad contact somewhere,check connectors under seat and at the dash lights in center stack.It also can happen when you change a bad battery or disconnect a wire with the power on,like when you remove the center stack for a new radio.The only way to get it off is to have a scanner with Mitsu SRS codes or take it to a mechanic that has one that can reset it.Most cheaper scanners that reset codes will not work.
chanaum
03-06-2016 02:37 PM
davidoneal
12-05-2015 07:59 AM
beefos
03-08-2014 05:32 AM
shum_87
08-29-2009 05:05 AM
dornstar
05-22-2006 04:58 PM
Quick Reply: SRS or airbag light on and won't turn off
