2006 Endeavor low idle / stalls
Hello all! First, thanks for a place to come and ask questions. Second, my question:
My wife drives a 2006 Endeavor, it's completely stock. She was having problems with it starting, come to find out it was a battery terminal I replaced a few years ago corroded enough between the wire and the terminal. I replaced the battery for good measure, cleaned the terminal and now it starts like a champ. However, if I start it and let it set it begins idling very low to the point of stalling frequently. I noticed that when the fan kicks on it idles just fine, hovering around 1000 rpm. When the fan turns off it drops to probably 300 - 500 and often stalls. Any suggestions on things to replace / check? Thank you!! |
Originally Posted by spencerisadog
(Post 319963)
Having the same problem
(Post 319963)
My wife drives a 2006 Endeavor, it's completely stock. She was having problems with it starting, come to find out it was a battery terminal I replaced a few years ago corroded enough between the wire and the terminal. I replaced the battery for good measure, cleaned the terminal and now it starts like a champ. However, if I start it and let it set it begins idling very low to the point of stalling frequently. I noticed that when the fan kicks on it idles just fine, hovering around 1000 rpm. When the fan turns off it drops to probably 300 - 500 and often stalls. Any suggestions on things to replace / check? Thank you!! did you figure out the problem ? |
low idle / stalling
Hi. Did this just suddenly happen? How many miles on car? Service history - well maintained? Any codes thrown?
I have an '04w/180K. Similar problem 'suddenly' happened. Check engine light said P0104. Low EGR flow. Just spent last few days R&R ing EGR valve,tubes. Cleaned thoroughly along with Throttle body. Runs great,no codes. > While doing these, I also did my valve cover gasket and spark plug tubes w/ new plugs for rear bank. Shouldn't have to fool with any of that stuff for awhile,if ever. If DIY, a few hours < $100. Stealership $$$! EGR alone is $400 ish.:( HTH. |
Did we find out the problem / solution?
