Endeavor wiring diagram?
Anyone have a wiring diagram for 2004 Endeavor? Fuel pump not making noise, but it runs when jumped with 12 volts. Both relays click. Is there a fuel shut-off switch somewhere?
I'll check the MAF sensor tonight.
It was running fine and suddenly wouldn't. Threw codes for camshaft sensor and crankshaft sensor. I replaced them both, but only cranks- won't fire.
I do have an aftermarket viper alarm. Could the starter disrupt malfunction and cause this?
My timing had jumped two or three teeth. A mouse made it's home inside the timing cover and got smooshed in there. I redid the timing and it started right up.
