Different offset wheels??
I've been looking at some wheel/tire options for the endeavor, and I was wondering, would it look ok with a staggered wheel fitment, for example, Use a 20 or 22 X 8.5 wheel in the front and 20 or 22 X 10 in the rear.
I've been looking at rimsandtires.com, and they have the endeavor listed as being able to fit 10 wide wheels in the front and back, but having them staggered I think would look nice. Any opinions and suggestions very welcomed. |
RE: Different offset wheels??
You would not be able to rotate your tires to make them last longer.
Ok I did a little better, more in depth research, and found that, the wheel with will be the same, for example 20 X 10, but the offset number changes, for example 20 X 10 with an offset of 30 per say, that would give me a bigger wheel lip in the back than the rear, and still use the same tires front and back.
I was looking at some pictures in Cardomain, of Trailblazers, they're somewhat comparable in size to the endeavor, and some had the staggered wheels, and they look real good. I'll probably try it. |
