Endeavor Resistor location
Hello, could someone please let me know were i can find the resisitor for the blower motor is? pictures of diagram would really help, thank you
2004 Endeavor Blower Motor Resistor Location
If it is for the 2004, when you remove the glove box, look at the duct running across the dash to the left
(looking through the area where you removed the glovebox.) About mid dash, you will see a connector to what looks like something flush mounted into the duct. That is the resistor, inserted into the duct. Their are one? or two screws holding it in place. They can be a pain to get to (at least for me...) but that is your resistor. Hope this helps. Roger |
Thank you very much roger that helped very much. I managed to find it and replace it. Yes you were correct it was hard to get at. I ended up going to Canadian tire And purchased a master craft mini wratchet set. Worked perfect. All in all thanks agin, the truck is blowing on all settings again. It was funny the motor sounded funny on setting 1 as it has not been able to Do that in a long time. I should add a pic of the old one, what a mess. Thanks again roger and the forum.
