error code P0506
On my 05 Endeavor my service engine light came on and the meter says, P0506, low idle RPM. I have no low RPM issues or rough running at all. Any suggestions what is causing the light to come on?
This information is from mitsubi****echinfo website.
This code is tripped when there is a difference greater than 100rpm's between the engine speed and the "target" engine speed.
"TROUBLESHOOTING HINTS (The most likely causes for this code to be set are
*Throttle valve area is dirty.
* PCM failed."
It says clean the throttle valve area completely, erase the code and see if it resets. It says the next step is to replace the PCM. Personally i'd try replacing the throttle position sensor and motor before I did that.
This is assuming you've already replaced the air filter and checked the housing.
* PCM failed."
catacami
Jul 21, 2013 12:30 AM
sp1viper
Apr 24, 2007 04:36 PM
