Front brakes
My Endeavor needs new front brakes (pads and rotors). I would like to do the work myself but want to make sure it is something I am capable of (I have done brakes on Eclipses before). It there a hub to take apart or anything? I want to be sure the rotor will pull right off after the calipers are off. Thanks in advance.
RE: Front brakes
I'm about to tackle the same project this weekend....without manual of any type. This is going to be fun.
RE: Front brakes
Hello Everyone...
Happy new Owner (3 months) of a used 04 XLS AWD and new to the forum.I have been very satisfied with the Endeavor...everything except for the I pod and Satellite radio inputs...or lack there of. I can see from thewear on the front rotors that mine will need to be replaced or atleast turned/re-surfaced. Has anyone tried any different types of rotors? Slotted/ dimpled or drilled ? I see there are some options for Endeavor rotors...unfortunately my research shows that Brembo rotors are not available for this model car which is what I planned on buying. If anyone has tried different brakes for this, please let me know what your results. I am skeptical because the front end of the car is quite sensitive to road conditions so the higher performance brakes (dimpled/slotted/drilled) might be felt through the steering wheel. thanks for anyones input |
RE: Front brakes
Sorry parts for the Endeavor is scarce.
Originally Posted by docgoku
(Post 230873)
Thanks in advance. Let me know if you need anything from owners manual. • After a new brake disc is installed, always grind the brake disc with on-the-car type brake lathe. If this step is not carried out, the brake disc run-out exceeds the specified value, resulting in judder. • M12 FLAT WASHER When the on-the-car type lathe is used, first install M12 flat washer on the stud bolt in the brake disc side according to the figure, and then install the adapter. If the adapter is installed with M12 flat washer not seated, the brake disc rotor may be deformed, resulting in inac- curate grinding. • Grind the brake disc with all wheel nuts diagonally and equally tightened to the specified torque 100 N⋅m (74 ft-lb). When all numbers of wheel nuts are not used, or the tightening torque is excessive or not equal, the brake disc rotor or drum may be deformed, resulting in judder. |
Got them done
I was able to change only the front pads without any problem. I didn't get any vibration or squeeks from using the exisitng rotors. I got the pads from the dealer and did price out rotors too. For anyone looking for aftermarket to save a little the dealership did say they offered only one rotor that has had good feedback. It was 30-40 dollars less that original. For anyone wondering the spec is 34ftlbs for the caliper bolts.
When I 1st change front disc brake on my other car. I had no idea. I researched and learned alot. I would suggest watching youtube videos to get the basics. There some very helpful videos with tips out there. Once you have a good idea then you can attempt on your own car. The principles are the same.
Lancer 2003 front disc brake
This will be 1st time, I am going to change front brakes for this car. I removed the calipers and noticed clips holding the brake pads. Earlier, I saw a you tube video where the owner changed the front pads of 2002 lancer and did not mention the clips. I have not proceeded to remove the clips. Do I need to remove the clips, what are the clips for. Can I install new pads without the clips?.
