Injector failures at 55,000 miles
My daughter has a 2004 Endeavor with 55,000 miles. The check engine light has been on so she took it to the Mit dealer here. They have diagnosed three bad fuel injectors. #2,4 and 6.
Does this seem even remotely reasonable for such low mileage? She has always used premium fuel and drives mostly on the highway.
If I am not mistaken, this would be all three injectors on one side of the engine. Why would that be?
They say they will fix the three failed injectors under warranty, but not do anything about the other three. Seems that if half the injectors have failed, the others would be very suspect.
Are the injectors really prone to fail so soon in the product life?
Can anyone shed some light on this issue?
Hank
Hank
90gsx I might know what you mean but, I hope you can prove that statement....
Injectors can always go bad especially internally...Many times In the part of the injector that is inside the Intake manifold leaks at times.Injectors go on and off all the time-Pulse width.ON time may be milliseconds but lets say a couple million times it does that of course it takes a toll.
I can say I never have replaced a fuel injector in abt 5 years i've worked at a dealer. Coil packs, plugs and wires I have replaced many many many times.
When a car has a missfire its 9/10 its igntion related. Fuel injectors are not a common problem for a missfire or check engine light.
Thanks that I didnt know they didnt have a servicable fuel filter.
gsx I understand where your coming from then...But the 9of 10 is wrong. I happen to be a mechanic also sir I usually do smogs and you would be amazed by how many times ive seen High HC(unburnt fuel) readings because of a leaky injector-seals inside the Intake manifold.Rich Misfire in which too much fuel is in the combustion chamber. But then again its hit and miss I guess
Do you only do emissions? If you also deal w/ driveability issues you'd know where I'm coming from.
Smog when customer comes in....Still work on car to make that extra few bucks
You two arent really helping him.
The fact is that IVE been working on mitsus for 17 years... and injectors do NOT fail on endeavors. period. Certainly not 3 at a time.
the tech misdiagnosed it, unless someone else has run something through the fuel system that is a particulate and physically clogged it solid... in which case it will happen again.
