Injector failures at 55,000 miles
Old Apr 13, 2009 | 11:28 PM
Blck3G's Avatar
Originally Posted by Manybrews
You two arent really helping him.
The fact is that IVE been working on mitsus for 17 years... and injectors do NOT fail on endeavors. period. Certainly not 3 at a time.
the tech misdiagnosed it, unless someone else has run something through the fuel system that is a particulate and physically clogged it solid... in which case it will happen again.
Ok....Tact may help next time.
Old Apr 16, 2009 | 10:25 PM
Obakemono's Avatar
Default They should not have failed
The injectors should not have failed, unless something electrically fried them or they mechanically clog. I'm not sure the MTBF (mean time between failures) but they should last a very long time (150k+). I have only had to replace an injector once, and that was a Bosch unit that was causing a smog fail (poor spray pattern) on a '85 Volvo. If the dealer is going to change them then change them ALL. If the check engine light comes back on then you know something else is causing the issue. Could be a failing coil or fouled plug. Or a harness issue.
Rob
Old Apr 17, 2009 | 02:26 PM
FAX68's Avatar
Do you think High octane fuel is the problem?
Old Apr 17, 2009 | 03:40 PM
dsm1990gsx's Avatar
That should have nothing to do w/ it.
Old Apr 20, 2009 | 05:34 PM
Manybrews's Avatar
octane rating as nothing to do with it.
you're SUPPOST to be using high octane fuel in an endeavor.
chrisbre
Jul 31, 2008 08:23 PM
gtiguy915
Jul 13, 2006 11:14 AM
NonToxic
Oct 12, 2005 07:06 PM
drachemorder
Mar 12, 2005 01:34 AM
idioteque
Jan 28, 2005 02:09 PM
