Removing Subwoofer Panel?
I was wondering if anybody knew how to access the subwoofer in the cargo section of an endeav.? I blew my sub last week and all I constantly hear is blown speaker. I see there are no brackets, screws, or molding. Thank you in advance for any information!!!
RE: Removing Subwoofer Panel?
on the side panel its self there is a cargo hook wit a 10mm bolt take that bolt out. on the floor panle there are 2 cargo hooks also 10mm take them out remove floor panel. fold seat forward and you should have access to 5 or 6 bolts also 10mm i do believe. remove them then pull the panel out slightly and disconnect the cig ligther and that should solve your issue
so do the endeavors come with a subwoofer by default??
i purchased a used 2004 and i dont see a speaker in mine. i turned the bass up and dont feel it when im in the trunk. if there isnt one in there can someone tell me the size i need. thanks |
dont look like you got one the size is a 8 inch woofer you must not have the highend audio set up so you'll need a amp also and wiring
if i have someone else do it, say best buy or a local audio shop, will they be able to put it in the molding where the factory one would be??
No sure I would suggest using Best Buy to do it but your local pro audio shop should be able to set you up. Just remember if your missing the sub its likely your car is also missing the amp and doesnt have the wiring at this point. So those will need to be run also. If you want the cables and everything run exactly as the factory would make sure to make this clear to them or they may run the wiring different and place the amp differently.
You may want to consider picking up the service manual for your car so you can find out exactly where the amp is located on factory placement (i think its under the drive side seat but I have an outlander so i cant say for sure.). DO NOT BRING THE SERVICE MANUAL TO THE LOCAL AUDIO SHOP ITS BAD MOJO. |
i just had two tens put in lol. it was a lot easier, cause i already had the tens
