-   Mitsubishi Endeavor (https://mitsubishiforum.com/forum/mitsubishi-endeavor-15/)
-   -   Timing Belt Change Question/s (https://mitsubishiforum.com/forum/mitsubishi-endeavor-15/timing-belt-change-question-s-45032/)
RAYZOR1234 Aug 16, 2013 12:54 PM
Hi all, I'm new to the forum as well as to the Endeavor. I am planning to do a timing belt change (120k miles), my original thoughts were that I would just change the belt and 2 pulleys but after some thought, do I really need to change the water pump and belt tension adjuster? Ive searched the forum and couldnt find an answer.
Thanks in advance.
Akzle Aug 16, 2013 05:51 PM
water pump, depends on condition when you get in there, idler pulleys/tensioner, yes, just do it.
RAYZOR1234 Aug 16, 2013 06:49 PM
All "extra" parts are on order. Have to make a couple of the special tools but all should go well. Still cant believe no one in the baton rouge area carries a timing belt tensioner wrench, a flat bar with a couple of roll pins and a cutoff bolt for the torque wrench is cheaper anyway. Thanks
Akzle Aug 16, 2013 07:33 PM
ive never used one...
Good luck. Post pics for the next person who comes along and asks...
petrencu Sep 24, 2013 11:26 AM
Yes it is specified by constructor to change water pump and belt tension to with timing belt, warranty reason .
