where is the blow motor resistor at?
have an 05, seems water killed my blower motor, so i replaced it, now when i cut the car on it will turn for just a second. Did some research on it and it seems my main problem is the resistor. Went to the dealership today and bought the part for 30 dollars and got a diagram of where it is.
The diagram is useless! If you could please tell me how to find where the resistor goes I will buy you 20 boxes of girlscout cookies, or a big thank you from Georgia. Thanks! Sarah |
you mean this relay ???? 2005 MITSUBISHI ENDEAVOR Blower Motor Relay
send me a copy of the diagram of where it is that you have mxmikie@gmail.com
no its not a relay, i can't seem to find the diagram online again, it was printed for my from the dealership. I did find it online from some site in russia.
I talked to a few people and it seems the car does not have both, that it either has a blower motor resistor, or transistor. The dealership gave me a resistor to fix my blower motor with, seems they gave me the wrong part |
blow motor resistor is located behind the gloves compartment.
oh, and thank you very much for writing back to me!
u betcha
Originally Posted by mxmikie
(Post 281119)
does the 05 endeavor have both a transistor and a resistor?? |
i have found the transistor, tore the glovebox off pretty much, it was easy to find, however like i said, if there is a resistor in there, i can't find it
it bolts into the fan case
| All times are GMT -5. The time now is 03:06 AM. |
