fuel pump
i have the walbro 255 pump that im going to put in but i dont no if i lost the extras it came with but can i use the old seals and parts with the new pump?
RE: fuel pump
you dont need anything to install the pump. I mean a harness would make it easier but you can just splice the wires in just as easy
RE: fuel pump
John there is not splicing needed, all you do is literally take out the old pump and put in the new. no wiring no harness at least not on mine
RE: fuel pump
i thought that was because you bought yours with the install kit for your car which was the plug
RE: fuel pump
the plug that your supposed to splice in I never did cause it was the same as the plug already on the pump. the 'install' kit is still sitting in the bottom draw at the shop where all my misc junk parts are
