intercooler piping
Old Feb 6, 2008 | 10:23 PM
southside's Avatar
Default intercooler piping
is injen a good company for intercooler piping for stock psi or should i good with somthing else.
Old Feb 7, 2008 | 06:13 AM
Default RE: intercooler piping
Injen i believe is fine for a stock system. I think as you look for more power it will become someone of a restriction just because of the design. Emonz actually has it on his 400+ evo and i think he was gonna be changing them out for something better. But for a stock turbo and boost they wont be a problem
Old Feb 7, 2008 | 07:12 AM
they are not bad BUT I would go with ETS pipeing kits if I could start all over again because they look alot better and routed better
Old Feb 7, 2008 | 05:57 PM
Rob's Avatar
Rob
I'll be going with the buschur piece and a small battery kit, myself.
Old Feb 7, 2008 | 06:12 PM
5280LANEVO's Avatar
Is a hard pipe kit that much better or should one just get a whole FMIC kit? more like is it worth it to get a hard pipe kit.
Old Feb 7, 2008 | 06:20 PM
depends on your mods. IMO the pipeong it is more for looks than anything. But there is also no need for a FMIC if your on the stock turbo in most cases. that asside with a piping kit you can alway use a different FMIC at a later time it takes very little to make them fit from the stocker IC to a aftermarket one. For example I was running the injen on my stock IC and now I have all these mods and a new FMIC and still running the injen up pipe
Old Feb 7, 2008 | 06:28 PM
5280LANEVO's Avatar
What's a good hard pipe kit? does HKS make one.
Old Feb 7, 2008 | 06:56 PM
ORIGINAL: 5280LANEVO
ETS
Buschur racing
AMS
all of those will be just as good or better than HKS and cheaper in most cases.
Old Feb 7, 2008 | 08:49 PM
southside's Avatar
thanks what i was going to get was the ams kit but hearing about the mts, its sounds better. but i look more in to it, if i was going to make my own, what kind of materials should i use for better performance and looks.
Old Feb 8, 2008 | 05:03 PM
5280LANEVO's Avatar
2.5 or 3" aluminum pipeing also get T-bolt clamps others seem blow off all the time.I used Vibrent universal pipe kit on my 240 and loved it.
