Quick clutch question
I'm really not sure if this has been discussed already, and I'm in a rush to get to the airport.
But I just need to know if the 06 Evo IX MR flywheele and clutch would work in a 05 GSR. My buddy bought an 05 GSR with a slipping clutch and just needs to get an OEM replacement till he can save and get an Exedy. He found a used OEM off a Evo 9 MR, just need to know if it works before I give him the ok. Thanks, Mike |
RE: Quick clutch question
the trannies are the same as far as I know. I dont see why they wouldnt be
Yeah, they are the same for the most part. But what do you think about the 6 spd vs the 5 spd?
Or is that not really taken into consideration when looking at the clutch and flywheel? |
the 6spd is prob differnt than the 5spd
Yo Rob, thanks. I got some good info, as well as a good laugh.
nice thanks Rob. I had no clue on that one. I went with the safe guess that they were different, Guess not
Hey guys, just t be a 100% sure about the flywheels for the 5 and 6 speed, I called Mitsu.
The part numbers are the same for the 05 GSR 5spd and 06 MR 6spd. I already knew that the clutches were the same, so now the identical part number confirms that the flywheels are the same for 5 and 6 speed Evo's. part # is nd373136 |
