stroker kit
where can i find a stroker kit? around how much will i be spending? and around what kind of horsepower will i be looking at if i want to keep the stock 16g with the stroker kit?
do you need to sleeve the blocks on evos? thanks alot for the answers. |
RE: stroker kit
why even stroke the motor on the stock turbo? But either way you can get built shortblocks or the internals and build it yourself.
www.buschurracing.com www.automotorsports.com are two of the biggest. or you can call turbotrix they do good work www.turbotrix.com |
RE: stroker kit
The stock internals can handle the max output of that turbo easily
| All times are GMT -5. The time now is 10:00 AM. |
