what's the difference????
Ok so im at work screwing around at work like aleways and found out the 2003 evos have 2 different engine the difference is the 8th number in the vin is either a F then the codes 122/01997 or its a ] then the codes 122/01998 wtf is the difference???
RE: what's the difference????
What makes you think the engine is different?
^^Usually the 8th number of the VIN is the engine code but you probably already know that.
Actually I didn't.
The engine is exactly the same... maybe they changed the way they do the vin? |
the motors are all the same. UK evos are different as the motors had different levels of power from the factory though. USDM Evos 03-04 are all identicle
