-   Mitsubishi Evolution (https://mitsubishiforum.com/forum/mitsubishi-evolution-50/)
-   -   WHY IS THIS SO CHEAP!!!! (https://mitsubishiforum.com/forum/mitsubishi-evolution-50/why-so-cheap-23755/)
EvoSpeed Nov 28, 2007 09:10 PM
Ok am I nuts or is this crazt cheap.
http://cgi.ebay.com/ebaymotors/MITSU...spagenameZWDVW
Don't these things usually run like $1600, and this also includes a new OEM throw out bearing.
Should I grasb this or does something look fishy
Thanks
EMonz57 Nov 28, 2007 09:45 PM
RE: WHY IS THIS SO CHEAP!!!!
Its the SD version so they are a few hundred cheaper and since he is selling it on ebay your maybe saveing a few extra bucks from there.
Its a Decent deal though for a awsome clutch. I have the HD version it is awsome. worth the $1500 I paid for mine
TheEngineer Nov 29, 2007 06:59 AM
yea i think the SD usually goes for around 1200 sot this is still a good deal for one
EMonz57 Nov 29, 2007 07:28 AM
ORIGINAL: TheEngineer
way to reword exactly what I just said John you newb
TheEngineer Nov 29, 2007 09:55 AM
i was just trying to give him an actual dollar value on that clutch
EvoSpeed Nov 29, 2007 02:21 PM
Is there much of a differance in HP/torq capabilities between the SD and HD
BEAT Nov 29, 2007 03:48 PM
Buy a Ferrari...justkiddin
EMonz57 Nov 29, 2007 06:26 PM
ORIGINAL: BEAT
WTF?? He is asking serious questions here. If you wanna be a putz and goof off please do it in OT or in a pointless thread, not trying to be a prick but I dont need to explain why im saying this lol:D
Now
The SD
Specs
Number of Discs
TWIN
Spring Damper Discs
YES
Clamp Load (Lbs)
2205
Disc Outer Diameter
200
Spline Teeth / Major Diameter
23T / 26.2
The HD
Specs
Number of Discs
TWIN
Spring Damper Discs
YES
Clamp Load (Lbs)
2920
Disc Outer Diameter
200
23T / 26.2
the clamp load it much higher on the HD. I think if I remember correctly the HD was good for 550tq and the SD was only like 400 or 450 or something like that but dont hold me to those numbers
EvoSpeed Nov 29, 2007 10:21 PM
Ok thanks being that these clutches last a pretty long time and I am eventually gonna build it up I will hold out for the HD then. Honestly that's probably why this dudes sellin it as well he wants the HD lol
EMonz57 Nov 30, 2007 09:02 AM
ORIGINAL: EvoSpeed
What clutches last a really long time? The stocker doesnt lol. any muti disc clutch is not a clutch that will last a really long time if you launch alot. its to clutched in one crambed into the same amount of space made for a single dics so intern parts are alittle thnner
they are awsome clutches and they are the best for your drivetrain
