2003 montero limited 3.8L very hard to start
Hi all montero! I have 2003 montero limited 3.8L.It very hard to starts may be one minute for key rotation then starts if I give gas.When engine started the idling is very good and no fluctuation.
I did so far: -new temperature sensor(every 2) -new battery -new starter -new generator -new fuel pump -new fuel pump filter -new fuel regulator -new PVC valve -new spark plug(6) -injector clean(check fine every 6) -fuel system pressure: 0 bar when ignition on -fuel system pressure: 3.2bar (when engine works) -throttle clean -Mass Air Flow Sensor(MAF) clean -EGR valve clean -engine pass with scaner(Autel MaxiDiag Elite MD802) -I put over the first fuel pump relay to the second fuel pump relay's space, than I put the second relay to the first relay's space. The car does the same as before. HELP! What more can I do? Sorry for my small English language knowledge. I'm waiting for answers and thank you forward. My Email:seksarithy@gmail.com |
any update to the issue?
In my 2003 Montero Limited this symptom was a faulty fuel pump.
Tee pump sounded like it was working, smelled fuel at the engine like it was working. But it had become weak and it wasn't until I replaced the fuel pump that I could start it up again. Now all is well... for now. |
