95 Galant 2.4 SOHC-no spark-test coil?
I've changed the ECM and distributor/coil with used...the code from the ecm says the computer is OK. Does anybody know how to test the coil off the car? There is a 6 pin conn. and a 2 pin conn. I get 1 ohm across the 2 pin. With 12 volt across the 2 pin, spinning the rotor, still no spark...Thanks...</P> |
These distribtors are not that great and are expensive. I bet that is you problem. </P> I would goto a junk yard and get a distributor and just change it out. Might be cheaper than digging into that one.</P><edited><editID>kccobra</editID><editDate>38042.3956944444</editDate></edited> |
