’95 Galant 2.4 SOHC-no spark-test coil?
Old 02-10-2004, 07:55 PM
lelliott's Avatar
Default ’95 Galant 2.4 SOHC-no spark-test coil?
I've changed the ECM and distributor/coil with used...the code from the ecm says the computer is OK. Does anybody know how to test the coil off the car? There is a 6 pin conn. and a 2 pin conn. I get 1 ohm across the 2 pin. With 12 volt across the 2 pin, spinning the rotor, still no spark...Thanks...</P>
Old 02-25-2004, 11:29 AM
These distribtors are not that great and are expensive. I bet that is you problem. </P>
I would goto a junk yard and get a distributor and just change it out. Might be cheaper than digging into that one.</P><edited><editID>kccobra</editID><editDate>38042.3956944444</editDate></edited>
Shadowplane676
07-07-2021 07:50 PM
davidsdlck
12-22-2020 06:51 PM
newoutlanderfan
12-04-2014 01:40 PM
ryant25bb
10-12-2006 12:54 PM
54321
04-07-2004 11:06 PM
Quick Reply: ’95 Galant 2.4 SOHC-no spark-test coil?
