01 Galant will not start!! HELP please
Ok i recently purchased this car cheap not running.. i first checked compression witch reads.
Cyl 1 - 180 Cyl 2 - 160 Cyl 3 - 165 Cyl 4 - 160 Seems ok not sure if they are to far apart to run but hey ya thats why im here. Has good fuel pressure, checked the coils and plugs for fire and yes they do. also i pulled off everything to re install timing belt and found the balance shaft belt broke i replaced it, R/R timing belt as well and i lined everything up to its correct point and reinstalled, it trys to fire and exhaust manifold its getting warm so its firing, it just will not start... please help |
Sorry its a 2.4 sohc
Any ideas I have checked a lot of stuff just can't find the problem, is there serval common Problems on these motors and answers will help.
| All times are GMT -5. The time now is 08:14 AM. |
