1991 Headlight removal
I just picked up a 1991 Galant for my son. The lower rear of the front quarter panels is rusted. In trying to take off the front fender to repair the rust I have found removing the headlight to get to fender bolts to be impossible.
Sounds like a stupid question but how do the front headlight and side light get removed. I can not see any obvious bolts to remove. Help? |
RE: 1991 Headlight removal
I had the same problem too, when I changed my headlights to jdm . But I found out by inserting a screw driver (flat head) between the fender and the turn signal light or park lamps ( be careful not to chip the paint or dent ur fender) u can push it towards the outside. if u already remove that then u will see the headlights bolts. but take note there is a spring that holds these lamps (that's why there's a little resistance when u push it, u may also look for it. one is near ur battery on the right side and the other is on the left. hope this helps......;)
