1993 galant 2.0L engine gearbox is damaged help pls
Hi all, so I recently bought a 93 automatic transmission galant . When i bought it the transmission was messed up. When u put the transmission to D, you could drive the car in first gear but as soon as the car shifted into second gear, it would go into neutral and the car wouldnt drive anymore. Also R didnt work at all(reason i bought the car is because it was cheap and even if i were to change the whole gearbox id still come out on top). So i asked around a bit and someone told me to switch out the filter under the gearbox and then also change the engine oil. So i did that and fortunately the rear gear strated working, but the rest was still the same. So now im just kinda stuck. I kinda feel like i could fix the car without having to switch out the gearbox so if u have any suggestions fire pls.
Hey how dirty was the oil from the transmission when you changed it? Make sure you add the correct oil that is specs for Mitsubishi. See if that helps if not you may need to change the Solenoides in the transmission. This is a high precision piece and needs to be maintained well.
